050224: Object codes must be in the range of 0 to 255.
The codes associated with object features that are used to train an object detection model for point clouds must be within the range of 0 to 255. This error occurs when one or more objects has a value that is outside this range.
Solution
Use the Calculate Field tool to reassign the values in the field containing the object code values so that they are within the range of 0 to 255.
