050230: Must specify a processing extent or boundary for this option.
The Classify LAS Ground tool's Recover Ridges ground detection option requires that a processing extent or boundary is specified. The option uses a specialized technique that should only be applied to locations where ridges were not classified by the Standard, Conservative, or Aggressive ground detection options.
Solution
Provide a processing extent or polygon boundary file that contains unclassified ridge points.
