050239: The model cannot be used because its voxel size <value> is too large.
This error can be encountered when the point cloud that is being evaluated with the object detection model has points of a different density than the point cloud that was used to train the model, or when the point cloud is very dense and the object being detected is very large.
Solution
Use the Thin LAS tool to reduce the density of points in the point cloud. This will ensure that the data has a consistent point density, which has a higher likelihood of being evaluated successfully.
