080327: Enrich Layer supports point and line features only when Data Source is set to your Portal. Polygon features are supported when Data Source is set to your Portal or your installed dataset.
Polygon features are supported when the Data Source environment is set to the portal or the installed dataset.
Solution
Set your portal or install the USA_ESRI_2024 dataset.
