080369: Using the Enrich tool with a local Business Analyst dataset requires Business Analyst software license.
Business Analyst may not be enabled, or an incorrect data source was chosen.
Solution
Use a correct ArcGIS Online data source, or reconfigure the Licensing options to enable the Business Analyst extension. After you enable the extension, select the USA_ESRI_2024 dataset under Environments.
To configure the Licensing options, click Project > Licensing, and click the Configure your licensing options button.
