080430: Failed to evaluate expression for feature <value>.
The feature expression could not be correctly evaluated. This may happen if there are syntactical errors in the expression or if there are invalid characters in the paths or names of the datasets.
Solution
Ensure that you are using the tool correctly and that you have specified the correct input and output paths. Also, make sure that paths that contain spaces are quoted correctly. Be careful when using spaces in the path.
