080447: Failed to generate average drive time for feature with OID <value> because the store point is not contained in the input polygon.
When using the Associated Store ID Field parameter, an approximate drive times polygon will only be generated if the associated store is contained within the associated input polygon.
Solution
Ensure that the associated Store Layer features are within their associated polygons (Input Features parameter values).
