080476: The value exceeds the GeoEnrichment service limit. Only the first <value> records will be returned.
The number of records exceeds the limit set by the GeoEnrichment Service.
Solution
Contact your administrator to determine the number of records that can be returned in the query. You can also do the following:
  • Switch to a local dataset.
  • Reduce the extent of the search area.
