080503: Failed to enrich a feature due to an invalid Standard Geography ID.
Enriching the layer failed due to updated or removed standard geographies in datasets. For example, an input layer was created with USA_ESRI_2022, and the current dataset is set to USA_ESRI_2023. The datasets must have the same geography IDs.
Solution
Re-create the layer using the Generate Standard Geography Trade Areas tool. Specify the Input Type parameter value as Table, use the input layer as the Geography IDs Table parameter value, and use IDField as the Geography Key Field parameter value.
