080504: Failed to create a report due to an invalid Standard Geography ID.
The report failed due to updated or removed standard geographies in datasets. For example, an input layer was created with USA_ESRI_2022, and the current dataset is set to USA_ESRI_2023. The datasets must have the same geography IDs.
Solution
Re-create the layer using the Generate Standard Geography Trade Areas tool. Specify the Input Type parameter value as Table, use the input layer as the Geography IDs Table parameter value , and use IDField as the Geography Key Field parameter value.
