080505: Threshold drive times were processed with STANDARD polygon detail. Only STANDARD polygon detail is supported when the Business Analyst data source is set to an online dataset.
The Polygon Detail parameter's High option is not available when the data source is set to an online dataset. The default setting will be used.
Solution
Accept the default setting for the Polygon Detail parameter, or provide a locally stored or installed dataset and specify the High option.
