080511: Find related POI option is not supported for this dataset.
The Find related POI parameter requires a local Business Analyst data source. When the data source is set to online, semantic search is ignored and the standard search method will be employed.
Solution
Do one of the following:
  • Ignore the warning and continue with the standard search results.
  • Ensure that a local data source is installed or connected and is licensed to use the Find related POI parameter.
To set the local Business Analyst data source, click Environments > Data Source.
