080516: The Input Features parameter has features that are in different time zones. The Generate Drive Time Trade Areas tool does not support features in different time zones when removing overlap.
For the Remove Overlap parameter, it is assumed that all drive times are started simultaneously. As a result, the tool will fail when this option is checked and drive times are different.
Solution
Run the tool with the Remove Overlap parameter unchecked, or specify the Time Zone parameter value as UTC.
