080552: Failed to create report: <value>. The report template references <value>, which is based on a missing dataset <value>.
The Business Analyst dataset that was in use when the template was created is not available. The template may be referencing variables from an older dataset.
Solution
Switch to the correct dataset or update the template to use the current dataset.
If the template came from the Business Analyst Web App, reimport the template while connected to the matching local dataset.
