090044: Error in running SQL statement while applying rule <value> to <value>, no action performed. The SQL statement is invalid.
The SQL expression defined in the specified rule is invalid.
Solution
When building an expression using the Query Builder, use Verify to confirm that the expression is valid. If Verify returns an error or cannot be used, review the expression, modify if necessary, and try again.
