090046: Error in running VBScript expression while applying rule <value> to <value>, no action performed. The VBScript expression is invalid.
The VBScript expression defined in the specified rule is invalid.
Solution
When building an expression using the Expression Parser, use the Verify button to confirm that the expression is valid. If Verify returns an error, review the expression, modify if necessary, and try again.
