090180: The selected input dataset is invalid for the following reason: <value>
The selected input dataset either uses a coordinate system that is incompatible with that of the BIS geodatabase, or it has no floating point or double field that has nonnull values.
Solution
Select a dataset that has a coordinate system that is compatible with the BIS geodatabase or has one or more floating point or double fields that have nonnull values.
