090182: The following fields have errors in them and must be corrected before the tool can execute: <value>
One or more fields in the extended metadata do not contain any value for a required field or has an invalid value because it does not fall within the range of values expected for that type of field.
Solution
Ensure that all extended metadata fields are supplied with a value if the field is required and that all specified values are valid with respect to the type of field.
