090197: The datasets do not share the same value for Vertical Units, Direction, or Dataset Type properties. This may fail at run time if the filter returns the same result.
The datasets must have the same value for Vertical Units, Direction, and Dataset Type. Mixed properties are not allowed for a model. If the filter returns the same mix at the time of execution, the tool will fail.
Solution
Update your datasets filter or selection to contain nonmixed properties.
