090258: The footprint polygon(s) of the following <value> dataset(s) were too complex and therefore not included in the final computation of the output: <value>
The footprint polygons of one or more datasets were too complex to derive and could not be taken into account when computing the footprints. If you're working with deconflicted footprints, the effect in the final output can range from major to virtually nonexistent, depending on the sort rank of the problematic datasets in the surface model.
Solution
This error is usually data specific. Contact Esri Technical Support for more information.
