090297: Error reading map products file: <value>
An error reading the map products file occurred. Typically, this only happens if the file was manually modified.
Solution
Review the error message to understand which syntax problem was encountered. Then modify the map products file that was installed with either the ArcGIS Topographic Mapping or ArcGIS Topographic Mapping product files installer.
