090305: Unable to get vertical unit from the specified data source. Meter will be used as the vertical unit for elevation values.
There is no vertical unit (z-unit) in the input's spatial reference.
Solution
If the input does not have a vertical unit defined, meter is used by default as the z-unit. To use a different vertical coordinate system, run the Define Projection tool to define a vertical coordinate system.
