090332: The GAIT batch file used to start the XServer process was not found.
The XServer process did not start because an expected GAIT file was missing. The expected format of the file name is rungait<version>-runx.bat, for example, rungait28-runx.bat. The file should be in the GAIT home directory.
Solution
If the file name has been changed to a different format, modify the GAIT_SESSION_CONFIG.xml file in the <ArcGIS Pro Installation location>\Resource\Defense folder, and set the XML BatchFileName element to the file name for the version of GAIT you have installed.
