110018: The Neighborhood Distance cannot exceed 75 percent of the maximum extent ... setting the Neighborhood Distance to: <value> <value>.
The value for the Neighborhood Distance parameter exceeds 75 percent of the maximum extent of the Input Space Time Cube value. The maximum extent is the distance covered by the longer of the cube rows or cube columns.
Solution
When the value is too large, the tool will calculate a valid Neighborhood Distance parameter value. Use this value or use another value that is less than 75 percent of the maximum extent of the Input Space Time Cube value.
