110024: <value> is not a variable in the Space Time Cube.
The Analysis Variable value does not exist in the Input Space Time Cube value.
Solution
Select an Analysis Variable value that is included in the Input Space Time Cube value. These will appear in the Analysis Variable drop-down list when you run the Emerging Hot Spot Analysis tool from the UI.
