110040: Features located outside the extent (only includes first 30): <value> = <value>.
These are the ID values for points that fall outside of the processing extent. Only the first 30 point features are listed.
Solution
If you do not want to exclude any points from your analysis, examine the points that fall outside of the processing extent. Then determine if the Polygon Analysis Mask needs to be extended or if the Template Cube should be re-created.
