110056: The spatial reference for the Input Space Time Cube (<value>) does not appear to match the defined output coordinate system (<value>). The output coordinate system has been used for visualization only.
The spatial reference of the Input Space Time Cube parameter value does not match the defined output coordinate system. The analysis was completed in the coordinate system of the input cube and the results were reprojected to the output coordinate system for visualization only. The visualization of these results may not be consistent with the results of an analysis that had been done in the output coordinate system.
Solution
Consider re-creating the Input Space Time Cube parameter value using the intended projection.
