110059: Projections between Input Features and Candidate Features are incompatible. Analysis has been performed in WGS_1984_Web_Mercator_Auxiliary_Sphere projection.
The Input Features parameter value was not projected to the coordinate system for the Candidate Features parameter value because the projections are incompatible. The analysis finished in the WGS_1984_Web_Mercator_Auxiliary_Sphere coordinate system.
Solution
To use a coordinate system other than WGS_1984_Web_Mercator_Auxiliary_Sphere, consider reprojecting both datasets into an alternative coordinate system that both inputs can successfully reproject.
