110062: The Template Cube provided was created using an old version of that has a substantial logic flaw. If you would like to use a Template Cube, you can re-create your cube.
The initial release of this tool contained a substantial logic flaw. This was corrected at ArcMap 10.3.1 and ArcGIS Pro 1.1, and patches are available for earlier versions of the software. You must re-create any cubes built before the patch.
Solution
Re-create the cube or call Esri Technical Support if you have questions regarding the patch.
