110064: Failed to create the Output Space Time Cube due to the Summary Field <value>. Reconsider the chosen Statistic and Fill type for this field.
The cube was not created due to a problem with the statistic type or fill type for the Summary Field parameter value. This may be due to a large number of null values, a large number of empty bins, or a lack of variation in the timestamps of the features in this field.
Solution
Inspect the specified field for <null> values and ensure that the timestamps associated with the existing data fall into 10 time slices. Also ensure that the statistic type and fill type are appropriate for the Summary Field parameter value. Ensure that the Time Step Interval parameter value and the Distance Interval parameter value do not result in a large number of empty bins, as this affects the ability to estimate empty bins based on the specified fill type.
