110108: You must provide a Time Step Interval to construct a Space Time Cube From Defined Locations with the options given.
A Time Step Interval parameter value is required.
Solution
Specify a Time Step Interval parameter value to define the temporal extent of each time slice.
The value is the number of seconds, minutes, hours, days, weeks, or years that will represent a single time step. Examples of valid entries for this parameter are 1 Weeks, 13 Days, or 1 Months.
If the Temporal Aggregation parameter is unchecked, you are not aggregating temporally and this should be set to the existing temporal structure of the data.
If the Temporal Aggregation parameter is checked, you are aggregating temporally and this will be the Time Step Interval value you want to create. All features within the same Time Step Interval parameter value will be aggregated.
