110125: The Maximum Constraint provided resulted in <value> clusters.
Setting the Maximum per Cluster parameter to a value greater than the total sum of the value or to a number greater than the number of features in the dataset may result in one cluster returned or other unexpected results.
Solution
Review the number of features in the dataset or the total value of the constraint field you are trying to use. Confirm that the value provided for the Maximum per Cluster parameter is appropriate for the analysis.
