110126: The number of user provided seeds is greater than the desired clusters... randomly selecting <value> of the <value> seed features.
Seed features are identified by a value of 1 in the seed field. One seed feature is needed to grow each cluster. The tool found more seed features than clusters specified in the Number of Clusters parameter. Consequently, the tool will randomly select seed features from those you identified.
Solution
If you don't want to see this warning, you can modify the seed field you provided so the number of seed features (values of 1) matches the Number of Clusters you specify.
