110136: You must provide a Constraint Field when using Attribute Value Constraints.
You have selected Attribute Value for the Cluster Size Constraints parameter. You must specify the field with the attribute values you want to use to constrain the clusters.
Solution
Specify a field that indicates the values that should be used to constrain the clusters.
