110141: The Minimum Number of Features per Cluster is greater than the number of features in the dataset.
The value you specified for the Minimum Number of Features per Cluster must be less than the total number of features in your dataset in order to create clusters.
Solution
Check to see if a selection set is active. Check the total number of Input Features in the dataset. Choose a value less than the total number of features.
