110163: A Minimum Search Distance value must be provided when using Manual intervals with this Neighborhood Type.
You must provide a value for the Minimum Search Distance parameter when the Neighborhood Type parameter is set to Distance band and the Neighborhood Selection Method parameter is set to Manual intervals.
Solution
Provide a value for the Minimum Search Distance parameter or choose a different option for the Neighborhood Type or Neighborhood Selection Method parameter.
