110167: A Distance Band value must be provided when using User defined with this Neighborhood Type.
You must provide a value for the Distance Band parameter when the Neighborhood Type parameter is set to Distance band and the Neighborhood Selection Method parameter is set to User defined.
Solution
Provide a value for the Distance Band parameter or choose a different option for the Neighborhood Type or Neighborhood Selection Method parameter.
