110194: The Variable type in the training dataset <value> dataset is different than the variable <value> in the predicted dataset.
At least one field from the Explanatory Training Variables parameter that is specified as Categorical is matched to a field from the Match Explanatory Variables parameter that cannot be represented as a categorical variable.
Solution
Determine which field from the Match Explanatory Variables parameter cannot be represented as a categorical variable and provide a different field.
The most likely reason that a field cannot be represented as categorical is that it is stored as a Double or Long type.
