110206: The variable type is different between <value>.
All fields in the Explanatory Training Variables parameter must match the field types of the equivalent fields in the Match Explanatory Variables parameter. At least one field has a different field type.
Solution
Determine the field that is not matched, and provide a field of the correct type.
A common source of this error is a field containing numeric values stored as a text field.
