110236: The dataset is unbalanced, the variable to predict contains the following categories with <value>
At least one of the categories in the Variable to Predict parameter contains relatively few values, which can reduce the accuracy of the model.
Solution
No action is required, but consider running the tool again using the Compensate for Sparse Categories parameter.
