110242: There is not enough variation in the Dependent Variable for at least one local neighborhood.
At least one local model contains values of the Dependent Variable values that do not have sufficient variability.
Solution
Identify any local areas where the Dependent Variable parameter has nearly all the same values, and remove any Input Features values from that area.
Alternatively, use a different Neighborhood Selection Method option to include more values in each local model that may have sufficient variability.
