110245: A location with <value> coincident features exists, which must be less than the default Minimum Number of Neighbors (<value>).
The number of input features sharing the same location (coincident features) exceeds the default value for the Minimum Number of Neighbors parameter. This is not supported because some locations use neighbors that are all coincident and lack spatial variation.
Solution
Manually provide a value larger than the default for the Minimum Number of Neighbors parameter. Alternatively, remove some of the coincident features.
