110247: The following variable(s) on the right side need to be removed since they are not selected as Explanatory Variables: <value>.
All fields provided for the Explanatory Variable(s) parameter must be matched to equivalent fields in the Match Explanatory Variables parameter. At least one field is not matched to an explanatory variable.
Solution
Add a field o the Explanatory Variable(s) parameter to match the unmatched field.
