110264: The explanatory variables perfectly explain the dependent variable, leaving insufficient variation to calculate the statistics.
The Dependent Variable value can be perfectly explained by the provided Explanatory Variable(s) value, leaving insufficient variation to calculate statistical summaries. For example, predicting temperature measured in Celsius based on the same temperature measured in Fahrenheit will result in this error because the temperature in Celsius can be perfectly determined by the temperature in Fahrenheit.
Solution
Determine which explanatory variables perfectly explain the dependent variable, and remove them.
