110308: The default Number of Neighbors used in the analysis was <value>.
The tool used the default number of neighbors in the calculation because the Number of Neighbors parameter was either unchanged or blank.
Solution
This is an informational message. The tool will use eight neighbors if the Number of Neighbors parameter is unchanged or blank. It is recommended that you increase the number of neighbors used in the analysis if there are many categories present in your dataset.
