110327: Not all of the Input Forecast Space Time Cubes have the same Number of Time Steps to Forecast.
The space-time cubes in the Input Forecast Space Time Cubes parameter did not all use the same Number of Time Steps to Forecast value. The Output Space Time Cube value will only contain the forecasted values for the fewest number of time steps of all input cubes. For example, if you provide two cubes, and one cube forecasts three time steps and the second cube forecasts five time steps, each location in the output will forecast the first three time steps.
Solution
No action is required. However, consider re-creating the Input Forecast Space Time Cubes value so that each cube forecasts the same number of time steps. This ensures that all forecasted values will be stored in the Output Space Time Cube value.
