110346: Cannot apply Log transformation to negative or zero values in the field(s): <value>
The Log option of the Transformation Method parameter cannot be used for fields containing all negative or zero values. The message displays all fields containing all negative or zero values.
Solution
Remove the identified fields or choose a different transformation method.
