110405: The Input SAS Dataset <value> could not be found.
The SAS dataset could not be found in the specified library.
This error is also encountered when trying to access data in a WORK library. This library is a temporary workspace that is only accessible in the current SAS session, and all files are deleted at the end of a session. This tool initializes a new session during each run, so it cannot access the WORK library of any other sessions.
Solution
Verify that the SAS dataset exists in the library.
To use data saved in a WORK library, save the data to a permanent library.
