110426: Prediction values could not be calculated for <value> of <value> raster cells due to explanatory variable values outside of training data ranges.
When predicting to raster and not allowing predictions outside of the data ranges, each continuous variable provided in the Match Explanatory Rasters parameter must only contain values within the range of the training data. The number of cells in the prediction raster with values outside the input data ranges is displayed in the message. These cells contain NoData.
Solution
No action is required. However, you can use the Allow Predictions Outside of Data Ranges parameter to allow extrapolated predictions.
