110459: The specified subset time span is greater than or equal to the input space-time cube's time span.
When subsetting by time, the time range of the subset must be within the time range of the input space-time cube. This error can occur in three conditions:
The user-defined start and end times that are outside the range of the input space-time cube.
The number of time steps to remove exceeds the number of time steps in the input space-time cube.
The input temporal subset cube has a wider time range than the input space-time cube.
Solution
Use different options of the Temporal Subset Method parameter and dependent parameters.
